Sound problem ipad2
bartosz2010
I gotta problem with ipad 2. All sounds in apllications stopped working - eg background sounds in games. I checked everything general settings and apllications settings and they are well set. Speakers seems to work too. Does anybody have same problem? Is therevany chance to solve this situation ?
Try resetting by push and hold power and home button a few second until screen blank, iPad will restart will clean configuration.
This method get me out of trouble so far.
I am having same problem with my ipad2. It was working until this morning
Are you really sure that you've checked the settings?
Try doing this, go to General>>Reset>>Reset All Settings
Then when you use the slide tab on the side of your iPad, slide it up and it will be "unmuted", maybe your device just got muted.
