radumarinescu
I have the following problem and I am really desperate.
First, here is the context:
- I have an iPad jailbreaked with iOS 4.2.1 (of course, tethered) which I forgot to charge for a couple of days and the batter got completely drained
- I started recharging it, using an original 10W wall charger for iPad
- the iPad starts charging (I see the "red battery" with the flash sign on the screen) and after a while the silver apple logo appears on the screen, but the iPad never boots...and if I leave the iPad untouched (and plugged in the charger) it goes back to the "red battery" screen... and the cycle starts over.
I tried to put the iPad in DFU mode in order to boot tethered (using redsn0w 0.9.6b4) but unfortunately I can't manage to enter DFU mode...although I follow the timing provided by the redsn0w tool
... Here is how I do this (may be it's wrong):
i. when the apple log is on the screen, I remove the cable and press Home+Power until the screen shuts off.... I assume that this is the "TURN OFF" state.
ii. I plug-in the cable in the iPad ... at which moment (without pushing any buttons) the iPad starts and the Apple logo appears...
iii. then i try to follow the timing sequence from redsn0w (Power - 3sec, then Power+Home - 9 sec, then Home - 15 sec), but I never reach the DFU mode... instead, every time the iPad ends in a state with the screen black (like it would be completely shut down)
One more thing: I would not mind even restoring the iPad! ... and I even managed to reach the "Connect to iTunes" window. However, the iPad never get recognized by iTunes... I tried it on three different Mac computers, and in Windows on a VM... but it never got recognized by iTunes.... by reading the Apple instructions, they emphasize that the device must have at least 20% of battery when entering Recovery mode, which is certainly unachievable for me
due to the fact that the iPad never charged beyond the point (threshold) at which it switches from the "red battery" screen and tries to boot)
So, my questions are:
1. Did this ever happened to you? Or have you heard/read about such a situation before?
2. Is there a way to make my iPad charge (and not stop charging after the "red battery" level is reached)?
3. Do you know *any* way in which I could restore it... or enter DFU mode?
I have jailbreaked in the last 2 year everything from iPod touch to iPhone to iPad, with various versions of tethered and untethered jailbreaks, so I have some experience in doing this... but this problem is beyond my capacity, and I am really desperate, because I am totally clueless.
Any help is welcome!
Thanks a lot,
radu
Thanks a lot,
radu
