Ipad has serious wifi problems
FatalDesain
I'm up to owning three ipads now all used 16gb and all of them at some point will not connect to a network. Belkin routers seem to cause it more. Settting ip to static or the reverse seems to fix it but its very annoying.
Ipad has been out for a while and theynstill have not fixed thia issue. And i have tried this with some pretty popular routers.
Just curious as to what firmware you are running on them?
I use WiFi at mainly at home and use 3G when not home. I use a Netgear N AP (not set as a router) and have ZERO issues. I am running 3.2 and am holding off upgrading mainly because I see WiFi issues being discussed more than I think is appropriate.
Apparently this is not a problem with Cisco/Linksys routers. My wife and I both use our home wireless routers (WRT54G2) without issue.
You also may want to check that none of your neighbors are using the same wifi channel as you. Android has a great App for this.
Running 4.2 used linksys routers, netgear, belkin. Wpa and channel is on auto. This happens like maybe one a week and have to restart router.
I use a Linksys (Cisco) E3000 and have no problems what so ever. My sister was using a Netgear and I had to change it out to a Linksys and have had no problems since.
I got the wifi router and man what a difference it made in the way my a
Idevises connect to internet and our wireless printer that was not working as far as not responding to commands wirelessly works now This is so nice.
Thank you all!!!
Thank you all!!!
Great news.. Did you get the E3000?
Ya my belkin is toast after a taste of this wifi router, I had a buffalo router before the belkin and I missed it so much, then got this one and this router is better then a buffalo.
