Importing movies using the Camera Connection Kit
Rends
Germany
If i understand correctly i can import movies from camcorder or digital cameras (SD cards or USB cable connected )with the Camera Connection Kit if they are stored in the DCIM folder.
Does this work with movies i got from itunes ( or DVDs i converted into the AppleTV format) too if i copy them into the DCIM folder of the SD card?
I mean out of the box with no Jailbreak.
Hello and welcome to the forum! :)
Possible? Yes but not easily done - check out this THREAD for some suggestions - good luck and let us know if you find a better way?
Thx for welcome.
I will give your suggestions a try once i get the iPad and the connection kit :)
