JollyJoyce1
- Joined
- Mar 9, 2012
- Messages
- 8
- Reaction score
- 0
I have my iPad connected to my computer and it is not charging the battery while connected. Is this correct? I thought it automatically recharged while connected. Help please.
KevinJS said:USB does not supply enough power to charge the iPad. Although it will maintain charge, or even charge it slowly, the iPad will not indicate that it is being charged.
If you do a search of this forum, another member has found and posted a software solution, which you could try. I haven't tried it myself but there is a program which will increase the power supplied through USB to that required by the iPad.
JollyJoyce1 said:I have my iPad connected to my computer and it is not charging the battery while connected. Is this correct? I thought it automatically recharged while connected. Help please.
The IPad WILL NOT CHARGE plugged into a computer you MUST use the supplied charger or one of the many iPad docking stations
Sorry, but I have to correct this: Even though the iPad says it's "not charging" when connected to a computer, it actually is. Granted, it's a very slow trickle charge and is very inefficient versus being plugged into the main electrically - but it is charging.
However, the best way to charge the iPad is indeed with a wall charger or dock...
