Axdobe problem
mickeymost1
Is there anyone who can tell me if I can get a app or download an adobe flash for my I pad 2, there are times when i need it but my I pad says it is not Capable of putting 1 on.
Thanks very much
Flash is not supported for the iPad. If you do a search, there are many threads pertaining to this topic. You can do a work around and purchase apps like I swifter to help you get around this if you so desire. This app as well others available all have it's limitations.
Good luck!
Thanks very much, do you know if the swifter will let me see items that need flash player, as I will buy it if it helps.
For me I wanted to access some the games that Facebook had. That is the reason for my use. I am not sure what it is all capable of, but you can check out their website online and get a better idea. I found that it was slow ad clunky-and slowly discontinued its use.
Thanks, very much for your very quick response, give yourself a pay rise I will check the web site. Happy new year
