Small problem that I need help with!
Discussion in 'iPad Help' started by Lgb0250, May 2, 2013.
  1. Lgb0250
    Lgb0250
    Apr 29, 2013
    5
    I've had my IPad for quite awhile now but we just got my wife's IPad today and in the process of setting it up.
    We set her up a mail account with no problems except its syncing with mine!! I was showing her how to delete my folders in iCloud on hers when all of a sudden I realized they were disappearing from my IPad also! Not good.
    Do I need to set her up her own iTunes account in order for both of them not to sync together? I named hers different from mine but it doesn't appear that that is enough.
    Thanks for the help
  2. MoonlitSonata
    MoonlitSonata
    iPad Ninja
    May 8, 2011
    2,390
    170
    Yes you need separate accounts with iTunes.
  3. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,935
    6,119
    Hi & welcome to the forum! :)
    I'm assuming that your wife's account is setup w/ a different login name and password (regardless of using the same email client - we use Yahoo)? If so, I'm not sure why you may be having the issues described - I don't use iCloud, so not sure if that would be a consideration - others may have to help?
    Now, I've had an iPad 2 for 2 yrs and just bought my wife an iPad Mini - I set her up through my Apple account so we could download my purchases to her iPad, so far has worked fine for us - not sure that there is an easy answer to your question, but please post back your specifics on setting up your wife's account and how you may be using iCloud - good luck! Dave
  4. Lgb0250
    Lgb0250
    Apr 29, 2013
    5
    Thanks everyone.
    Looks like once I deleted my iCloud account from her IPad and then set her up with a separate account, all is well. Unfortunately I lost several folders from my IPad before I realized what was happening. Live and learn I guess.
    Again, thanks
