Random Popping/Crackling Noise
Discussion in 'iPad Air 2 Forum' started by Sebastian82, Feb 20, 2015.
  1. Sebastian82
    Sebastian82
    Feb 20, 2015
    Hello
    first sorry for my english, I'm from Germany and do my best.
    This topic is already being discussed in various other forums but maybe someone here has an idea.
    My Ipad Air 2 know regardless of the installed software on a sporadic crack.
    Meanwhile, the unit has been replaced twice and even the third know the same problem.
    The pop occurs sporadically e.g. when you lock or unlock when playing videos or tap the address bar in Safari. Mainly one perceives the problem with battery charge between 90-100%.
    My previous Ipad Air 1 never had such a problem.
    The devices have been restored with Itunes and always set up as a New Ipad. ICloud disabled.
    The only solution to eliminate the annoying sounds is put off the keypad tones in Settings.
    The best way to provoke the problem is the method which is presented in my youtube video.
    Should there be a software problem is that every Air 2 show these problems.
    Has anyone of you this problem or Ipad Air2 without these symptoms?
  2. Brian 244
    Brian 244
    Oct 20, 2014
    457
    525
    Hmmm, I've had the Air 2 for 2 months now and have not come across this. Almost seems like a static electricity discharge.
  3. The OB
    The OB
    Staff Member
    Aug 10, 2012
    4,616
    1,642
    Hi Sebastian and welcome to the forum. I'm somewhat relieved to see your post. My Air2 has also been doing that on occasion, not enough to be a real worry, but now that I see someone else has that "problem" I'm less worried.
    I suspect that has been somewhat of a trade-off with the physical thinness of this iPad body. There have been worries too about the speakers giving off a vibration in the body, something I sometimes feel too. I'm no expert but I think the thinness of the body has caused some limitations in the performance of the speakers. Maybe those "popping" or vibration sensations are due to the speakers resting up closely to the iPad Air2 body. To me this is not at all worrying. But if it really continues to concern you I would suggest you discuss this at your Apple store.
    Regards, Andrew
    Andrew
    Sent from my iPad Air2 using Tapatalk
  4. Tweak2
    Tweak2
    Jun 30, 2011
    34
    6
    I have the same cracking noise on my Air2. Maybe once a week with no consistent app in progress. I haven't worried too much about it. Glad to see there are others experiencing this.
  5. Caesars
    Caesars
    Jun 6, 2012
    16
    I too have this issue, glad it's a quality control issue and not just me lol.
    G3/i6
  6. donn70
    donn70
    Feb 28, 2015
    same here and right out of the box while in app store search field. it happened 3 times within 5 minutes after setup. i just purchased this on thursday too. glad to report it hasn't happened again...........
    ok, it happened twice while in app store again.
    #6 donn70, Feb 28, 2015
  7. Clemdog
    Clemdog
    May 1, 2010
    16
    Yup. Happening with mine too.
apple charge pop noise
ipad air 2 noise
ipad air 2 pop noise then lost sound
ipad air 2 random popping sound 2015
ipad air 2 speaker pop
ipad air popping noise
ipad makes crackle noise
ipad speaker crackling
ipad speaker crackling sound
random apple sound crackling
