problem with cellular data on IPad 2
Discussion in 'iPad Carriers' started by iluvbdon, Jul 1, 2011.
  1. iluvbdon
    iluvbdon
    Jul 1, 2011
    I just purchased a new IPad 2, I still have my original IPad also. I cancelled my cellular data plan on the original IPad and setup the new cellular data plan on the new IPad 2. Everything looks like it is connected, I have ATT bars at the top. The data plan shows that it is active, yet I can not hit the internet unless I turn the wi fi on......has anyone else had this issue?:confused:
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
  3. Kaykaykay
    Kaykaykay
    iPad Wizard
    Apr 28, 2011
    6,970
    446
    I didn't cancel anything. I just switch the micro-SIM card between my iPad 1 and 2. Works fine.
  4. iluvbdon
    iluvbdon
    Jul 1, 2011
    Thank you for your assistance, after spending the afternoon on the phone with AT&T, evidently I had a bad SIM card in the IPad 2 that I purchased. AT&T put in a new SIM card and I am good to go.
  5. meowin0921
    meowin0921
    Jul 6, 2011
    Ialso have the same problem
  6. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
    Did you try transferring your account as it suggested in the article I posted? I know one of the posters simply swapped their SIM and the OP found they had a bad SIM, so maybe your SIM is bad too.
  7. Kaykaykay
    Kaykaykay
    iPad Wizard
    Apr 28, 2011
    6,970
    446
    I've been swapping my SIM between iPad 1 and 2 for months without problem. I didn't transfer or otherwise change my AT&T unlimited account, which is grandfathered.
    I checked with AT&T and the rep said there were no restrictions against the swapping back and forth. I also had the rep note in my account that I'd checked, in case any problems arise in future. I've used the same account since the debut of iPad 1's 3G model.
cellular data account ipad 2 not working
ipad cellular data problem
ipad cellular data problems
ipad cellular problems
no cellular data on ipad 2
