Jailbreak not wrking(. Help?
wing_
Hi, i'm having troubles with jailbreak.
Before without jailbreak apps wherent installing on ipad, now with jaibreak they are intalling, but when i lunching them its crashing and not working, and it is with third app like this. Maybe i didnt something with jailbreak.
Can anyone help me?
iPad-Sweden
Sweden
Did u sync back the apps to the iPad after a upgrade and a jailbreak ?
If thats the case u will sure notice that the apps that crashes It the non legal bought appstore apps and the apps legaly downloaded works fine.
Delete and reinstall the crashing apps and they will work again.
W
wing_
This is the help forum so i'm typing here. Is this wrong?
I'm installed apps after i update and jailbreak ipad.
There are not crashing but when im lunching them, the are lunching and closing.
I was jailbreaking ipad with Limera1n, after i installed cydia and AppSync for OS 3.2.
Maybe i didnt something.
ps. I heard that i have to install free app from appstore first, but that didnt worked.
lrg32
Oceanside CA
You have appsync installed, so that means youre trying to transfer cracked apps huh? Not good, but if any apps crash at start-up, delete them from the ipad and re-sync them from your computer.
