iTunes sync problem.
Video from PC to IPad
So I have a a few videos in itunes on my laptop and I syn them over to my ipad but they show up in videos on the ipad I would like them to show up in itunes so I can put them on a presentation on keynote. Does any one have any suggestions?
my itunes doesn't show the sidebar I need to download photos
Hi, I'm a new user of iPad and this forum. I cannot figure out how to get to the starting point for moving my photos onto my ipad, and I think it's a problem with itunes. I've reinstalled itunes (having done so initially and got the ipad going with email, contacts, calendar no problem). When I open itunes (from the all programs list on my pc, I now go straight to the store and can't seem to get out of it. Arrrrrrghhhh!!!!!!!!
Just buy your tunes from Amazon... No DRM and you put it on whatever device you want. I do not buy music, books or videos from Apple/iTunes store.
I second that! Although, I've been a long-time member of eMusic and that's my music store of choice the concept is the same. Non DRM with songs that can be traded between devices. I do use iTunes on occasion to review music videos and some TV shows but I can't remember the last time I actually purchased music from iTunes.
Under the "View" tab at the top of your iTunes screen check to see that this option is checked "Use Full Window For iTunes Store" If it is check-marked then uncheck it and you'll get your sidebar back.
Synced iPad with iTunes, songs are grayed out on the iPad and won't play
I just synced my iPad with iTunes on my PC to add more songs to the iPad. The process seemed to work fine, but when it was done and I went to try to play some of the songs, they are grayed out and won't play. Instead, the iPad plays the closest song that isn't grayed out. Any ideas?
