ipad 4 , often now, when connected to charger will not charge, no lightning symbol !
Discussion in 'iPad 4 Forum' started by zvonkokracun, Nov 27, 2013.
  1. zvonkokracun
    zvonkokracun
    Oct 1, 2013
    hi, since about 2 weeks charging has become difficult. sometimes when connected it will not show the lightning charge symbol top right corner and it also does not make that sound when you first plug in the charger. often it goes down to between 10 and 20 % then suddenly it charges again. it is problematic if i want to be out for the whole day and i can not charge. so far i tried to clean 8 pin contacts, reset the ipad to original settings, changed cable, chose many different sockets. no use. have other people had to change the charger itself ? also what is the proceedure to get a new charger. my ipad4 is less than 6 months old. no apple shop near.
  2. abababababab
    abababababab
    iPad Super Guru
    Apr 21, 2013
    4,147
    697
    I had a similar problem some days before. The iPad would not charge and then, when I would slightly push the 30 pin plug (for iPad 3), a lightning charger for you, it would again start charging. I recommend you to go to the Apple store ( I dont think there is any way to work it out from home), get another charger, see if it is charging. That way you can understand if it is a problem with the charger or iPad.
    Good luck! Welcome to iPF!
charger
ipad4 is not charging with no charging sign
