How to see and kill running application.
Discussion in 'iPad 3 Forum' started by naeemakhtar110, Jun 10, 2012.
  1. naeemakhtar110
    naeemakhtar110
    Jun 10, 2012
    11
    Is there any way or app to see and kill running applications?
  2. coolstuffs
    coolstuffs
    Jun 1, 2012
    87
    Push the home button twice then select the app/apps (shown at the bottom of the screen) you want to close.
    #2 coolstuffs, Jun 10, 2012
  3. Svenster
    Svenster
    Mar 19, 2011
    35
    As Cool has suggested, but you also have to press and hold an app icon till it wiggles and then press the red (-) in the corner of the app.
    Sent from my iPad 2 3G using Tapatalk
    #3 Svenster, Jun 10, 2012
  4. Czevski
    Czevski
    iPad Addict
    Apr 24, 2011
    1,097
    473
    If you have gestures turned on you can swipe up with four fingers to see the bar with previously used app. Tap and hold one until the minus appears, then tap the minus to completely close the app. Some of these apps are running but most are just in a waiting state. To return to the home screen just tap it.
  5. naeemakhtar110
    naeemakhtar110
    Jun 10, 2012
    11
how to kill an app on ipad
how to kill apps on ipad
how to kill ipad apps
ipad kill app
ipad kill apps
ipad kill running app
kill app on ipad
kill apps ipad
kill apps on ipad
kill ipad app
