Hi there--welcome to the forum!
Sometimes it's best to try to do these immediate fixes. See below:
1. Force the app to close?
2. Try to restart your iPad?
3. Try to do a soft reset?
You can try this in order, if an app becomes funky.
Force the app to close down*by pushing the home button twice to bring up your multi-task bar. This will show all the apps that you have visited. By long pressing the app in question, it will begin to jiggle-press the red circle with the negative sign on the app. It will only quit the app and not delete. Than try to re-open the app and test out.
Third is to do a soft reset by holding the power switch and home button together until you see the apple logo. Hope that helps!
