1. Grannyjo5
    Grannyjo5
    Jan 29, 2012
    I downloadedx a couple of tv shows from iTunes to my ipad2. It says they down loaded. How do I view them? Can't even find them. Help? :p
  2. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,938
    1,405
    Hi GrannyJo-have you tried to look in your "Video" App on your ipad? Try there and see. If not showing, let us know.
  3. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,828
    1,309
    Hi and welcome to the Forum!
  4. Grannyjo5
    Grannyjo5
    Jan 29, 2012
    Thanks for your response. Got it fixed. So far I am loving this IPad. Still have a lot to learn tho. You will probably be hearing from me again. Also, while I am at it... Once I have a TV show or movie downloaded? Will I need to have wifi access to view it? Preliminary question, as I haven't had the chance to try it yet. Hoping it will work on airplanes?
  5. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,938
    1,405
    No wifi needed. Once you have it loaded onto your iPad you can view at any time. However, if you rent a movie-you have 30 days to watch it. Once you begin the movie, you than have ~ 24 -48 hrs (not entirely sure) to view before it expires.
