Having Problems with Wi-Fi Sync
Discussion in 'iPad Hacking' started by rabbithutch, Jun 21, 2011.
  1. rabbithutch
    rabbithutch
    Jun 21, 2011
    12
    After jailbreaking the iPad last night, I purchased Wi-Fi Sync from Cydia and finally got it installed on both the Windows laptop and the iPad. When I open iTunes on the laptop then open Wi-Fi Sync on the iPad, the laptop iTunes gives an 0xE8000065 error.
    Googling has turned up a number of discussions about his error on both the iPhone and the iPad; however I've not found one that discusses the problem with Wi-Fi Sync and a jb'd iPad. Most of them have had to do with USB port problems. I do NOT have the iPad cable connected when I get this error (because the whole purpose of Wi-Fi Sync is to be able to sync without cabling).
    I need help to overcome this problem. I've uninstalled and reinstalled iTunes, QuickTime, et al and I've power failed and restarted the iPad. The problem persists.
    I know very little about jailbreaking (if anyone knows a good article on things to do AFTER jailbreaking, please post it) but liked the idea of trying new things. Most of my apps I brought over after jb'ng while still cable attached. They all work but some of them have lost there historical information. I need to get everything sync'd and want to use Wi-Fi Sync to do it.
    Thanks for listening. Hope some of you young geniuses can help an old man out.
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Are you using the latest iTunes?
    I don't believe WiFi Sync has been updated for a while and the PC application is quite particular about the version of iTunes it hooks into.
    The latest iTunes is 10.3, but AFAIK, WiFi sync was last stable on 10.1. Can I suggest you get in touch with the developer? I am sure he will provide support. You can get the details through Cydia.
    You can also log a support ticket with him from his website at Wi-Fi Sync for iPhone, iPod touch, and iPad
    Hope that helps.
  3. rabbithutch
    rabbithutch
    Jun 21, 2011
    12
    Thanks for the input.
    I found on rebooting my WinXP laptop that it would not start Wi-Fi Sync. The error message stated that the problem might be associated with my AV software. I'm still pursuing the fix.
    While I have your ear, are there other apps for wifi syncing besides Wi-Fi Sync? I'm not married to that app (especially if it is not being kept stable with iTunes releases) and would welcome opinions about what app to use for that purpose. As I've said elsewhere, I'm absolutely new to iPad hacks and have lots to learn.
  4. ColemanLee09
    ColemanLee09
    Apr 20, 2011
    73
    Wifi sync stopped working after updating from 4.3.1 iOS for me.
    Sent from my iPad 2 using iPF.
  5. rabbithutch
    rabbithutch
    Jun 21, 2011
    12
    Other Wireless Sync Apps?
    OK. I got burned for the $10 bucks, too, I guess. :mad:
    So, are there other apps that allow synching your iOS4 devices without the cable? If so, what do you folks recommend?
    TIA
  6. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Shame. You'll just have to wait it out till September and it will be built into iTunes and iOS5 officially... No other solutions in the meantime.
    However, have you tried downgrading iTunes to a supported WiFiSync version (10.1 I think)?
    In many cases you don't really NEED the very latest iTunes. You may find you can sacrifice a few unimportant features to get the one thing you want working again...
    Worth a try.
  7. rabbithutch
    rabbithutch
    Jun 21, 2011
    12
    Thanks. I'll give that a try. But, be forewarned. If I my google can't find it, I'll BE BACK! (You haff to iMAGine the djerman accent.)
  8. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Try here... Old Version of iTunes Download - OldApps.com
    Then uninstall current, and install "old" one you download...
  9. rabbithutch
    rabbithutch
    Jun 21, 2011
    12
    Thank you, mate!
how to fix itunes when using wifi sync cydia app
ipad wi-fi sync problems
ipad wifi sync problems
ipad wifi sync troubleshooting
ippad wifi sync problems
wifi sync 0xe8000065
wifi sync cydia not working
wifi sync vlc failed
wifisync.app error
wifisync.app error on boot
