Does not charging mean not discharging also??
Discussion in 'iPad 2 Forum' started by thedon, Apr 13, 2011.
  1. thedon
    thedon
    Mar 12, 2011
    28
    I am at work and haven't tested this yet so I'm posting here for answers. If I'm plugged into USB port on my computer, my iPad says not charging. Which is fine. I only have one adapter that I keep at home but I have iPad/iPhone cables everywhere. The question is, when it's not charging is it at least keeping the charge it has?
    #1 thedon, Apr 13, 2011
  2. Dorje
    Dorje
    Feb 7, 2010
    340
    Short answer, no.
    Long answer, the USB port on your PC will only trickle charge your iPad. If your are running Apps on it you may end up using more charge then I'd coming in. Best thing to do would be to fully turn off the iPad.
  3. thedon
    thedon
    Mar 12, 2011
    28
    Cool. Just wondering. Thanks
apple ipad not charging but not discharging
not charging or discharging
