Cooling case for outdoor use?
Discussion in 'iPad Accessories for iPAD 1, 2 and 3' started by Photobug_Fred, Jun 17, 2010.
  1. Photobug_Fred
    Photobug_Fred
    Jun 17, 2010
    Hi everyone. I am considering purchasing the iPad 3G for use at outdoor arts festivals as a vendor. We are thinking of using the iPad for onsite inventory and using the SquareUp credit card app to be able to accept credit cards at the fairs. We would not be in direct sunlight, but under a tent/awning. But even with that, down here in the South it is not uncommon to hit 95 F even in the shade. I am concerned about relying on the iPad in this type of environment and was wondering if anyone makes a cooling solution for the iPad yet?
  2. thehatguy
    thehatguy
    May 12, 2010
    125
  3. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,018
    You could just get a laptop cooler or put some fans nearby. Putting it into a case is the exact opposite thing you would want to do.
  4. RobertBasil
    RobertBasil
    May 26, 2010
    107
    I use mine outside in well over 100 degree temps here in Arizona for hours on end and have had no problems at all.
  5. Photobug_Fred
    Photobug_Fred
    Jun 17, 2010
    Cooling Case
    I agree in principal about putting into a case. What I was hoping for was that someone out there has created a "case" / enclosure / stand... that integrated some type of cooling technology so that the iPad could be used outside in the south during the summer.
    For outdoor festivals, the iPad could be an ideal solution for taking credit card orders, inventory, product advertising and display... all in one. But it certainly won't get used if the thing just shuts down at 95 deg F. Robert says he has used it in 100 F temps in AZ but hey its a dry heat :). Try it in 100F with 98% humidity! The issue maybe just one of a few units with build problems. But I don't want to lay down $600-$800 just to find out that it's not going to work.
best cooling ipad cases for the outdoors
cooling case for ipad
cooling ipad case
cooling pad for ipad
how to make a cooling device for ipad outdoor use
ipad cooler case
ipad cooling
ipad cooling case
ipad cooling pad
ipad cooling pads
