Battery Maintenance
Discussion in 'iPad General Discussions' started by TFarmer, Sep 10, 2010.
  1. pallentx
    pallentx
    May 28, 2010
    663
    5
    yep, I have read that as well. Also to clarify, the issue with keeping them at full charge has nothing to do with memory like the old NiCd batteries. Ill see if I can find the article again. Its something about the battery staying at 100% - like people who keep their laptops plugged into docking stations all the time. I dont remember if its heat or some chemical breakdown that happens. You don't develop a memory, but the overall life of the battery decreases.
  2. Hasty
    Hasty
    iPad Ninja
    Jun 2, 2010
    2,266
    22
    The great thing is that as computer users we are used to an upgrade cycle of every couple of years. I will certainly be buying the next version of the iPad even though I don't care about a camera, so battery life won't be a priority.
  3. Demandarin
    Demandarin
    iPad Addict
    Jul 26, 2010
    1,247
    22
    Hands down, the ipad has the best battery life of any electronic device this size and caliber. Im still not used to it yet. Lol. I always wanna plug it up to the charger, by habit. Im constantly usimg this for everything i can and battery still goes. Apple definitely scored big in this department. Unbelievable. People be amazed whn they hear how long the battery life is. Especially compared to laptops. Laptop needs at least 3 charges to keep up with our 1 charge. ;-). Saves time n they say time is money.
  4. STEVEMS2305
    STEVEMS2305
    May 23, 2010
    19
    Everyone has an opinion BUT this is from APPLE:
    Use Your iPad Regularly
    For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down).
  5. Sonny Burnett
    Sonny Burnett
    Mar 7, 2010
    752
    The standard procedure is to run the battery down to 20% before recharging it and allow it to go to zero once a month.
do i have to let my ipad died before charging it for the first time
how farcshould should you let your ipad battery run down
ipad battery maintenance
is it better to run down the run down the ipad battery
should an ipad battery be completely ran down before recharging
should i let ipad battery completely run down
should i let my ipad battery die
should i let my ipad battery drain before i charge it
should you let ipasd run down completely
