RaduTyrsina
News Team
If you’ve bought yourself a brand new iPad Air or the latest iPad Mini, then you’re probably on the lookout for some accessories. iPort, a mobile device accessory maker, has just launched the Charge Case and Stand for iPad Air and iPad Mini. iPort has initially launched the combo device for Apple's fourth-generation iPad and iPad mini, and now the company has made it available for the latest iPads.
The Charge Case and Stand, like the name says, is a combination between a charging case and a stand. It also includes two charging points for portrait and landscape docking and the stand is adjustable to three distinct angles for typing and FaceTime. Ari Supran, CEO of iPort said the following:
We are huge iPad fans. The most amazing thing about iPad is its user experience. Charge Case and Stand is over a year in the making as the team worked through many designs to deliver the right concept that served to elevate the iPad experience by allowing you to use iPad while it charges in many orientations and keep it protected on the go.
Derick Dahl, Product Manager, added the following:
We studied nearly every iPad accessory that existed and found that most only supplied a piece of the necessary user experience. Most users mix together combinations
of stands, chargers, cases and the result leaves more to be desired. There had to be a better way. We wanted to create an accessory that married these elements together, and that by doing so provided a better experience.
The Charge Case and Stand costs $119.95 for the iPad Air and $99.95 for the iPad mini with Retina display. These are the same prices as for the iPad 4th generation and the original iPad Mini.
Source: AppleInsider, iPort
