iMovie seems to keep recorded audio clips
DrHouse
Hi all,
I need a bit of help with iMovie on the iPad. I've been using iMovie a lot these days and often, I will record audio clips to comment the video.
The things is that there seems to be no way to deleted the recorded audio clips once I'm done. What I mean is that I can remove them from the timeline, but I cannot remove them from the Recorded list. So I assumed that by deleting the project, I would get rid of them... Doesn't seem to work either. The space used by iMovie does not change indicating that the audio clips are still there.... Last time, I had to delete iMovie and reinstall it to reclaim the used space on my iPad. Any idea?
Vicopad addick!
