I could not find my post about let us invent something but anyhow I've got it. Problem was that lil device sold for 20 bucks will not fit on my Belkin case to divert the sound at your face sooo.
To get more volume at you than just out to right, just take a credit card or any card like a credit card cut a slit in it so you may slide it down on the elastic closing strap in just the right position to have a couple of inches poking out from behind the speaker then bend the card a little towards the front and bend the corners down a bit...voila you have it. Sounds so much better.
I think I may cut out the space on the case for the speaker too instead of just having the little holes punched into the leatherette material in order to let more sound out.
I like the Belkin case but it does not line up well with the iPad in that the iPad sags downward, but the feel and the ability to set your iPad up on a table or in your lap with this case is great.
