iPad won't play BBC iplayer on my wifi but will on neighbours.
This is a discussion on iPad won't play BBC iplayer on my wifi but will on neighbours. within the UK iPad General Discussions forums, part of the UK Dedicated iPad Forum category; I'm a new member and have an iPad one without 3 g. Up until 2 weeks ago I could get BBC iplayer. I can use ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    99750
    Sep 2011
    Sussex
    6
    I'm a new member and have an iPad one without 3 g. Up until 2 weeks ago I could get BBC iplayer. I can use wifi in all other apps where required, but not bbc iplayer. In settings I am connected, plus wifi icon shows at top of screen. Message on screen when I try to use iplayer says I must connect to wifi to make bbc Iplayer work, but I am connected. I have switched router on and off, have reloaded iplayer numerous times. If I use my neighbours wifi connection i can make iplayer work. My broadband provider is Aol, my neighbours uses talk talk. Help I am at a loss.
    116 times
    15,249
    99750
    Sep 2011
    Sussex
    6
    Unable to play BBC iplayer
    I've tried deleting the app as described, and have turned iPad off completely for 10 mis, but still says must connect to wifi!
    Any other ideas?...
    116 times
    15,249
    OK - that procedure doesn't delete the app, it simply quits it completely. Do you have the latest version of iPlayer? The reason I ask is that, when I updated to the latest iPlayer app I found that it would now work on 3G too. OK - I know you have a WiFi iPad but I was surprised that you got that error message.
    OK - try one more thing, which helps in a number of cases. Go into 'Settings', 'WiFi' and tell it to 'forget' your WiFi connection. Now, when the iPad finds your WiFi again you'll have to re-enter all the various passwords and/or encryption keys as it will look like a new WiFi connection to the iPad.
    See if that fixes the problem and don't hesitate to get back in contact if the problem still persists...we like a challenge!!
    99750
    Sep 2011
    Sussex
    6
    Still no luck
    Thank you for ideas, have done everything suggested and still I get the message "must connect to wifi" when trying to use BBC iplayer. Everything else working on wifi. Any more thoughts?
    Janey
    116 times
    15,249
    This is really weird. Do you get that message straight away when the app starts up, or do you see the app's Home screen first and you only get that message when you actually try to watch a program?
    96925
    Sep 2011
    This is happening to me as well. Have done all you suggested, but still get the message re wifi.
    99750
    Sep 2011
    Sussex
    6
    When I tap the iplayer icon up pops the page with all programmes, I can select a programme and it loads the home page for that programme. It is when I press the arrow in the middle of the screen to start the programme that I get the exceedingly irritating message must connect to wifi.
    Janey
    103734
    Sep 2011
    Gloucestershire, England
    5
    I am having the same problem. Used to be able to use iPlayer and now can't. Could the problem be with aol? They are my provider too.
    116 times
    15,249
    It certainly works just fine for me. I'm not sure how the service provider, AOL, would be an issue but, hey, anything's possible. Can you access iPlayer via the website with Safari?
  1. Neighbours needed for Zoo Story
    By felixwhoals in forum Friend Requests
    Last Post: 05-13-2013, 11:12 AM
  2. Farm Story Neighbours
    By Hobowhite in forum iPad General Discussions
    Last Post: 04-26-2013, 06:41 AM
  3. Zoo story neighbours
    By Mpower96 in forum iPad Games
    Last Post: 05-29-2011, 03:22 PM
  4. Does BBC iPlayer app play flash?
    By Bruce S in forum iPad Help
    Last Post: 03-19-2011, 09:57 PM
  5. BBC iPlayer, won't play videos
    By tom1252 in forum iPad General Discussions
    Last Post: 08-02-2010, 04:28 PM
aol problems iplayer
bbc iclick wont play ipad
bbc iplayer australia wont play ipad
bbc iplayer ipad wont stream
bbc iplayer please switch to a wi-fi ipad
bbc iplayer wifi connection
bbc iplayer won't load
bbciplayer says please switch to a wifi connection
my iplayer on my ipad will not play
my iplayer won't work on ipad
please switch to a wi-fi connection
will bbc iplayer work on ipad
