I books problem
This is a discussion on I books problem within the UK Dedicated iPad Forum forums, part of the Regional iPad Groups category; I there, I am new to the forum, but I have a problem, when I look at a catalogue on a website in PDF format, ...
I books problem
I there, I am new to the forum, but I have a problem, when I look at a catalogue on a website in PDF format, and try to open it
In I books, it briefly appears in PDFs and then disappears, I want to keep it without connecting to my lap top, anybody any ideas?
07-02-2012 03:41 PM
iPad Ninja
Hi David.... - welcome to the forum!
First, I would suggest that you 'Force Close' iBooks, i.e. open the multitask bar at the bottom of the screen (double tap the home button or use multi-fingering gesturing, swipe up); press and hold on iBooks until the icon jiggles, then press the 'minus sign'; return to the home screen & try again); if this does not work, then 'Restart' and if not effective 'Reset' the iPad (Directions HERE, if needed). Please post back your results - might help others.
Second, if you want to check out another great app & PDF reader (among its many features), take a look at GoodReader HERE, just a $5 purchase - this is the program that I use for my PDF files - good luck!
Originally Posted by
davidautomotive
I have tried that and it is still the same, if I go to I tunes and download the PDF on my computer and put it into books, it syncs ok with my I pad
And puts the book in the PDF section for it to be put under a different heading, if I go on a website and and download a book or PDF and then
Try to open in I books it appears briefly and then disappears, this is a problem that has just happened, I used to be able to do this ok
Hi have you managed to get this sorted out?
iboof
No not yet, but I tried again yesterday, and it worked twice, then it would not work the third time, I don't know if it is the size of the file, perhaps I may try using Dropbox?
davidautomotive
I have tried to do this in Dropbox, it doesn't work with that either, I tried a small file
I have used iBooks for PDFs but it can be iffy at times. File app pro is a good app for all files I haven't had any problems yet and use it all the time.
64GB wifi ipad2 iOS 6.1.2 (Jailbroken using Evasi0n) : 120GB iPod Classic (Filled with Rock Classics!) : AppleTV 2G iOS 5.0.2 (Jailbroken using seas0npass) : iPhone 3GS 16gb iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 3GS 32gb iOS 6.1.2 (My Rambling Tool is now Jailbroken using Evasi0n) : iPhone 4 16GB iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 4S 64GB iOS 6.1.3 (Stock, so I can stream Sky Go)
TheRambler
I can see what you mean, and the app is very good, but it has the same effect when you try and open it in I books
What is it you are wanting to do with with PDF?
- You may not post replies
- You may not edit your posts
Forum Rules
By sirius7bark in forum New Member Introductions - Site Assistance
Last Post: 02-21-2012, 09:44 PM
By kanderna in forum iPad Help
Last Post: 10-12-2011, 12:22 PM
By Maura in forum Apple iPad News
Last Post: 05-17-2011, 01:33 PM
By Dilayne in forum iBooks
Last Post: 10-24-2010, 07:15 AM
By JohnnyApple in forum iPad General Discussions
Last Post: 04-01-2010, 07:32 AM
bookshop problem with website
i books problem
problems with books on ipad
