You tube problem
Chandramohan
All of a sudden you tube videos have stopped loading midstream. I don't think it's a network issue since I tested the same content at the same time, on the same ISP, on the same WiFi on my iPhone. The iPhone finishes loading fine. But the iPad does not. This is a recent problem that seems to have stated after I upgraded to IOS 4.3.2. Any ideas?
Tim SPRACKLEN
