Xcar360-ELM 327 Bluetooth OBD2 Car Diagnostic Interface Code Scanner
Discussion in 'Off-Topic' started by 2012jack, Sep 7, 2012.
  1. 2012jack
    2012jack
    Jul 24, 2012
    • OBD-II Software for ELM327 USB is a free program that allows you to use your PC and a hardware interface to get the information from your car's computer.
    • The Bluetooth ELM327 has no cable, it works via bluetooth wirelessly.
    ELM327 Bluetooth Function:
    1.Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
    2.Clear trouble codes and turn off the MIL ("Check Engine" light)
    3.Display current sensor data, including:
    4.Engine RPM
    5.Calculated Load Value
    6.Coolant Temperature
    7.Fuel System Status
    8.Vehicle Speed
    9.Short Term Fuel Trim
    10.Long Term Fuel Trim
    11.Intake Manifold Pressure
    12.Timing Advance
    13. Intake Air Temperature
    14.Air Flow Rate
    15.Absolute Throttle Position
    16.Oxygen sensor voltages/associated short term fuel trims
    17. Fuel System status
    18.Fuel Pressure
    ELM 327 Bluetooth OBD2 Car Diagnostic Interface Code Scanner- $22.00
elm 360 diag
elm 360 interface
obd2
software scanner obd2 for ipad1
xcar360
