Wireless webcam to use as baby monitor
Discussion in 'iPad Accessories for iPAD 1, 2 and 3' started by madameJ, May 15, 2011.
  1. madameJ
    madameJ
    May 14, 2011
    11
    was wondering if there existed a wireless webcam that I could use with my Ipad 2 as a baby monitor?
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Have a look at the 'My Webcam' app in the Apple App Store, which allows you to view webcams on your iPad.
  3. Kaykaykay
    Kaykaykay
    iPad Wizard
    Apr 28, 2011
    6,970
    446
    Wouldn't that tie up your iPad from other uses? Aren't baby monitors supposed to be on constantly while you're away from the kid?
  4. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    That's a good point, because you couldn't have both apps open at once - or display a separate webcam window on the screen, while you work on something else. Though it might be possible to keep the audio on....
  5. madameJ
    madameJ
    May 14, 2011
    11
    Thanks Tim! I think I found one online for 30 $ that i can use when i am outside and baby is sleeping. Should work nicely instead of walking in and out every 20 minutes. I was just wondering if apple had it's on WEBCAM that was meant to go with ipad 2 but i guess it doesn't matter.
    Merci bien
baby monitor using ipad forum
imonitor baby monitor apple
ipad baby monitor webcam
mbg601w
using ipad as baby monitor
using wireless webcam as baby monitor
wireless ipad webcam
wireless webcam baby
wireless webcam for baby
wireless webcam for ipad
