wireless keyboard problems with ipad 2
Discussion in 'iPad Accessories for iPAD 1, 2 and 3' started by Suee, Jan 13, 2012.
  1. Suee
    Suee
    Jan 13, 2012
    I connected my apple wireless keyboard up with my ipad2. A number of the keys are all scrambled. The z is a y....the @ is an A...etc. Moved it back to the imac and it works fine. I see no place on the ipad where the lay out paramenters can be changed? Help!
  2. Temp31
    Temp31
    Dec 19, 2011
    133
    Did you make sure your settings are set to English (USA) and not some other language/country?
  3. Suee
    Suee
    Jan 13, 2012
    I couldnt find any setting for the language, but after your question went back to general settings again and finally found it 4 levels down in the menus..language was set to english, but the keyboard hardware was set to german....how that happened I will never know!
    Thanks for your tip
  4. keitacannon
    keitacannon
    Dec 9, 2011
    7
    Hi Suee - how did you get your iPad 2 to stay "connected" to your Apple wireless keyboard? I have to "re-pair" the devices and even then, the keyboard just stops typing completely; it will not respond. I've tried fresh batteries, turned off all bluetooth devices... nothing will allow the keyboard to work (even though the iPad 2 shows it as being "connected". Thanks for any info you can provide!
ipad 2 issues with apple1314 wireless keyboard troubleshooting
ipad keyboard y and z switched
ipad wireless keyboard problems
issues wih wireless keoard for minie ipad
problems with belkin wireless keyboard for ipad 2
trouble shoot my zapp key pad 4 ipad 2
trouble shooting for wireless keypads for ipad
why is my y and z swapped on ipad keyboard
wireless ipad keyboard issues
y and z moved on ipad keyboard
