Wireless Keyboard Help!
Discussion in 'iPad 3 Forum' started by ke5jwc, Apr 24, 2012.
  1. ke5jwc
    ke5jwc
    Apr 24, 2012
    6
    New IPad3..new Wireless Keyboard. Successfully paired yesterday. Today...not so much. Keeps searching in "now discoverable" mode but cannot find it. The keyboard has fresh batteries...is right up against the IPad...hit the on button...nothing...held the on button...nothing...the green light on the keyboard does come on for a few seconds. Hey, I know this is not rocket science so does anyone have any suggestions or do I have a bum keyboard?? Thanks...
  2. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,935
    6,119
    Hello & welcome to the forum! :)
    Well just to be simple & quick, I would check the batteries (if you have a battery checker) or try a set of new batteries - probably not the reason since you state 'fresh' batteries but will do no harm. I've had the Apple BT keyboard and the batteries should last a while. Good luck and please post back if you discover the problem!
  3. ke5jwc
    ke5jwc
    Apr 24, 2012
    6
    Tried new batteries right out of the package...checked them with my battery checker and both properly charged...no luck...tried two more batteries...no luck? Wonder if my keyboard is defective??
  4. panchucko
    panchucko
    Mar 12, 2012
    68
    Try going into setting on iPad and forget the bluetooth device and readd.
  5. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,935
    6,119
    OK - so not the batteries, sorry would have been the simple answer - now, I own the iPad 2 and have not had a connection issue w/ my KB (at least up to now).
    If you have a family member or friend w/ an iPad, you could attempt to 'pair' it w/ their device; or, if you bought the iPad/KB locally, then return to the store and have them check out both - you're still under warranty and a 'free' replacement would be a likely outcome.
    Good luck again! :)
  6. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    I just checked my BT keyboard, and found that a long press on the button will disconnect it. It take only a very brief touch to connect it. I suspect a hardware fault, particularly if you have successfully paired and connected the devices in the past.
    FWIW, I hadn't used my keyboard for several weeks, but pulled it out to check things for this question. It connected immediately, and the batteries are several months old.
    All I can suggest is don't hang on to that button. One touch and release should be all that's needed.
    Sent from my iPad 4 HD mini
  7. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    I'm assuming you've gone through the process of forgetting the KB and repairing it?
  8. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,417
    436
    I've had this problem before....I had to go well away from my router and other computers...then it connection would be made. I think sometimes bluetooth and wifi have problems together.
  9. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    They use the same antenna, apparently. Just checked this out, which you could also try. Turn on "Airplane Mode" then try to connect the keyboard.
  10. ke5jwc
    ke5jwc
    Apr 24, 2012
    6
    Problem Solved
    OK, here's what happened. Went back in to my settings and noted that WiFi was off. That came as a surprise to me because I have been connected to the net all along. Clicked the WiFi on and the KB responded. Cannot figure out
    why I have had complete access to my home network while the WiFi indicated it was off.
    Thanks everyone for your input and suggestions. I am 64 years old but have been involved with PC's since the 70's. Some things are very obvious to me and others not but always enjoy learning new things!!
can not discover keyboard
how do i set up my wireless keyboard with my ipad 3
i cant set up my wireless keyboard to my ipad
ipad cannot detect wireless keyboard
ipad cannot find apple wireless keyboard
ipad cannot find wireless keyboard
ipad cant find wireless keyboard
ipad wireless keyboard discoverable mode
king dragon wireless keyboard setting
what to do if ipad cant find wireless keyboard
