Wifi/Router Problems
Discussion in 'iPad Help' started by lb04081956, Dec 31, 2011.
  1. lb04081956
    lb04081956
    Jul 7, 2011
    9
    Out of the blue, my Ipad 2 will no longer connect to the router. It's not the router because my son connects with his Macbook. When I log off the Wifi and log back in, it sees and connects for just a few seconds then disconnects. Any suggestions?
    Thanks in advance.
    LB
  2. lb04081956
    lb04081956
    Jul 7, 2011
    9
    UPDATE: I figured out that the router needed a firmware update and that solved the connection problem, but every time the iPad goes to standby, it disconnects from the router and I have to reenter the password. Would this be a router or iPad configuration problem?
    Jack
ipad no router in wifi
ipad will no longer connect to router
