WIFI help
Discussion in 'New Member Introductions - Site Assistance' started by melnmiguel, Jan 8, 2012.
  1. melnmiguel
    melnmiguel
    Dec 18, 2011
    I am still trying to get onto my new ipad2. I have high speed internet for my home computer, although no router, just the modem. Also have xbox connected to modem. My ipad is not picking anything up, in order to turn WIFi on. Do I need to plug ipad2 into the modem as well? Hope you can tell what I'm trying to say. Any suggestions,
    #1 melnmiguel, Jan 8, 2012
  2. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,404
    Welcome to the forum!!
    So no wireless connection? No wifi, your iPad cannot connect. You may want to invest in a router, otherwise your iPad will not be able to connect to the Internet, unless you go somewhere with free wifi.
    #2 skimonkey, Jan 8, 2012
  3. melnmiguel
    melnmiguel
    Dec 18, 2011
    I have a router. Just haven't been using it. So, if I don't have a router hooked up, does that mean I don't have wireless?
  4. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,404
    Correct--fire that baby up!!
  5. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,831
    1,306
    Hi and welcome to the Forum!
  6. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,404
    You can always get a mobile hotspot device, such as virgin mobile-to get you on the net...or use your cell phone wifi. Just some alternates if you choose not to use your router.
  7. melnmiguel
    melnmiguel
    Dec 18, 2011
    My cell phone has wifi, but its a work phone. Its an HTC Evo Swift 4G. Would I need to get a password from my employer, or is it in my phone somewhere?
  8. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,404
    Try this:
    Create a hotspot with cell phone - Google Search
    You may want to consult with your work as well, since it may incur extra costs to use it as a hotspot. You can purchase a virgin mobile broadband wifi for about $100 and pay as you go. Not sure if this is an option. Realize that it may not be as fast as what you are accustomed to having with your home Internet.
    #8 skimonkey, Jan 8, 2012
