WiFi help
Discussion in 'iPad General Discussions' started by psmoore, Oct 28, 2010.
  1. psmoore
    psmoore
    Jun 27, 2010
    71
    I'm just wondering if any of you are having problems with the Wifi as of late? I can connect with my wifi at home with zero problems, but at work it shows the the signal strength and in the settings it shows the name of the wifi but won't connect. Is there a way to manually connect that I'm missing? Thanks alot.
    Paul
  2. BrennB
    BrennB
    iPad Addict
    Jun 13, 2010
    1,278
    6
    Try forgetting work network and reestablish connection. All can be done in network settings
