Wifi/ Cellular Monitor Thoughts
Discussion in 'iPad General Discussions' started by NSquirrel, Nov 20, 2014.
  1. NSquirrel
    NSquirrel
    Oct 22, 2014
    439
    320
    As I am still in learning curve mode with new Air 2, I installed 'Data Monitor' and 'My Data Mgr' to monitor my home wifi initially. (Both apps in free version mode.)
    My question concerns what they are measuring, as it appears that the results, what they show each day or through the day, are different and I wondered if anyone had any thoughts on this?
    While wifi monitoring is not really important, cellular will be so I would like to have some faith in what is being reported. Perhaps a different app would be more reliable? (BTW, I am on ios 8.1.1, if that make any difference)
    TIA, Nick
  2. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    28,019
    9,905
    Some cellular carriers have their own app where you can check your billing details and your data usage.
  3. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,872
    6,897
    The carrier's app or website is the only reliable way to monitor your data, especially if you have more than one device on the same data plan. Most carrier's offer warnings when you approach your data limits (via email or SMS). Visit your account on their website and make sure those are set up the way you want.
    Consider the iPad's data a good rough estimate, for that iPad's usage alone. Anytime you are pushing your data limit, check the carrier's stats. You should also hold in mind that the carrier's stats may be up to 24hrs behind, so leave yourself some room for error.
    Anything that measures your home wi-fi should be considered diagnostic, or just informational. Unless you've got limits on the home data as well; in which case your ISP should have similar tools for monitoring and warning you about your data usage.
    It's not so much that the data on your iPad is less accurate, as it is that you data provider could care less what your iPad says. It's what they measure that counts against your bill.
  4. NSquirrel
    NSquirrel
    Oct 22, 2014
    439
    320
    O.K. Thank you both for your comments above. Time to think about the next stage of my learning curve - cellular.
    Nick
  5. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,872
    6,897
    You're welcome.
  6. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    28,019
    9,905
    You're welcome.
measuring cellular data usage on an ipad air 2
