Which software to rip my dvds - then load on to ipad using cam connector kit.
Discussion in 'iPad Apps' started by hogmonay, Jun 26, 2011.
  1. hogmonay
    hogmonay
    Jun 26, 2011
    Hello all, I'm very new here and looking For some help, please! Before purchasing my iPad 2, I looked at options for backup storage and read the blurb ( including from Apple) that photos, music and videos could be added using the Apple Cam Connector, I have successfully used this method for photos but struggling with videos, seems a wee bit inconsistent. I have tried several free and trial DVD rippers to rip my DVDs into mp4 files that are recognised by iTunes and can easily be played on the iPad when dropped from iTunes via pc connection. I am now aware that the videos played from the cam connector kit don't play in the IPod function or from The Videos app but play from the photo gallery instead. I have (as stated) had limited luck in converting DVDs to files that work in this way - often the iPad doesn't even display the respective icon in the "camera" window and on some occasions when the videos are displayed and subsequently downloaded off the cam/SD card they will not open. I have had some successes but all from Trial software which will cost me £30 to £50 to subsequently purchase. I don't have a huge issue with making a purchase, though would like to first confirm if any of the freeware options do work and if so, what I am evidently doing incorrectly. thank you for taking to read and hopefully someone out there has a solution.... cheers
    Paul
  2. Byron
    Byron
    Dec 29, 2010
    22
    Handbreak
    Handbreak is free and it is great. I have converted over 200 DVD's and all work great. Handbreak have default settings for iPad, iPod, and Apple TV. They also have a generic apple default setting which works on all apple devices, this is the one I use.
  3. Padeasel
    Padeasel
    Dec 4, 2010
    57
    Hand break works great!
    Just yesterday I used Handbrake with my MacBook Pro to rip a DVD and uploaded the ripped file using iTunes to my iPad 2. You may be prompted to download another free program for it to work so do as recommended. It worked beautifully, not only did the video look good on the iPad, it also worked perfectly when using the HDMI adapter and HDMI cable connected to my TV. My Bweasel iPad stand also added to the convenience.
loading dvd onto ipad
loading dvds on ipad
