Volume problems
Discussion in 'New Member Introductions - Site Assistance' started by jams5870, Nov 2, 2011.
  1. jams5870
    jams5870
    Nov 2, 2011
    Hi,
    I'm James from Ireland. Delighted with my new iPad (August)
    My only gripe is the volume has recently started to cut out and I am having trouble getting it back.
    The entire thing goes mute in all applications and the volume toggle doesn't affect it, the system isn't muted using the settings or the mute button available at the bottom of the screen (following a double tap of the home key)
    Sometimes hard resets work, other times turning it off and on, other times playing with the mute and sound settings works. Mostly, I'm getting an ulcer.
    Anybody have any more specific fixes?
    Thanks,
    James
  2. Jeeper
    Jeeper
    Nov 14, 2010
    436
    8
    Other then a possible hardware problem, which I think I've heard of before on some iPad 2's (also weird volume issues), I might suggest turning off Bluetooth (if you use it) it's possible it's trying to grab a headset or speaker box (again, if you've set something up once). You may be in for a trip to an apple store. Search these threads for volume issues, I know there've been a few.
  3. jams5870
    jams5870
    Nov 2, 2011
    Thanks,
    I'll give that a go.
  4. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,912
    6,084
    Hello Jams... - welcome to the forum! :)
    Seems like you've already gone through my recommendations, i.e. check the volume control on the upper right side, make sure your volume switch is on, and also check your 'Settings' and the multitasking bar - if all of these seem to be correctly set and you are having problems w/ multiple apps, then this may be a hardware issue w/ the iPad - since a recent purchase (and not sure if you bought this locally or by mail order?) - I'd probably take the device back to an Apple store for a possible replacement - good luck! :thumbs:
  5. jams5870
    jams5870
    Nov 2, 2011
    thanks,
    For some reason it has sorted itself out.
    I don't know how, or if, I sorted it or if it is going to happen again.
  6. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,912
    6,084
    Hi James - glad that your sound is back & hope that it stays that way!
    Not sure what the problem may have been but good luck - Dave :)
  7. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Good to hear from you. You’ll find a whole bunch of iPad enthusiasts in this Forum who are only too willing to help other iPad owners and to hear of their experiences. Don’t be afraid to post any questions you may have or use the ‘Search’ button near the top of the Forum web page. I usually find I discover one new interesting and useful piece of information about my iPad every day - and often not even what I was looking for!!
    Hope to hear from you soon with your thoughts about the iPad.
    Have fun and enjoy your iPad
    If you don’t already have it you can download a copy of the iPad manual for free.
    Apple - Support - Manuals
    Please read the rules too!!
