volume control
Discussion in 'New Member Introductions - Site Assistance' started by tina4201, Jul 9, 2012.
  1. tina4201
    tina4201
    Jul 9, 2012
    8
    Hi all, just wondering if anyone else finds the volume control counterintuitive. i am constantly turning volume down when I think I'm turning it up and vice-versa. Every audio device I own (and I have a lot) increases gain by turning or initiating movement to the left and decreases gain going to the right. The ipad is the opposite. If I push on the right side of the button for volume control it increases volume and pushing left side decreases it.
  2. dhewson777
    dhewson777
    iPad Ninja
    Feb 23, 2012
    1,589
    163
    It just depends on how you hold the ipad, whether you need to adjust the volume left or right. Essentially you can hold the iPad in any orientation, so for some positions, the volume may work opposite what you are used to. I guess Apple have oriented the volume to work up and down with the home button at the bottom.
  3. tina4201
    tina4201
    Jul 9, 2012
    8
    I just realized I have the scenario backwards, going clockwise should increase gain, counterclockwise should decrease. So hitting button on right side should increase, tapping on left side should decrease, but ipad is opposite.
    As far as changing the orientation, doesn't work for me as I use it in landscape mode 99% of the time and want the volume control accessible on the top.
  4. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,225
    Well, it really depends on orientation - so it's half and half. For example, I, too, keep my iPad in landscape. But, my Home button is to the left, which puts my volume controls on the bottom. This makes them work "properly" for me - right is to increase volume, while left is decrease.
    So, yeah, for half the time, the buttons will be orientated "wrong." That's one of the compromises for having a device that can be viewed in 4 different ways. Two views will always have the buttons different...
counterintuitive volume button
ipad reverse volume buttons
ipad reverse volume control
ipad volume control backwards
ipad volume control reversed
my ipad has no volume control
volume control
volume control on ipad reverse
volume switch on ipad is backwards
why are volume controls on i pad backwards
