Verizon IPAD on Sprint or Virgin Mobile with built in 3g radio
ewalker3
West Palm Beach, Florida
I know the ATT ipad can run on Tmobile if you put in one of their sim cards, but I was wondering if the verizon ipad can be activated on sprint or virgin mobile using the ipads 3g radio as opposed to a mifi or other hotspot style suggestion?
laserguy007
Coral Springs Florida
As CDMA does not have a SIM card it would not be possible.
Sent from my iPad 2 White 64GB + 3G Verizon using iPF
Tim SPRACKLEN
Another point to take into consideration is that Verizon iPad will work almost nowhere else in the world except the US and a very few other countries. The Verizon CDMA standard is not supported in many other countries so, if you're planning to travel abroad, the AT&T iPad is really your only choice.
E
ewalker3
Thanks. I am familiar with the CDMA vs GSM worldwide discussion.
So even given sprint or virgin the ESN # to the verizon ipad they still wont activate it?
laserguy007
No only one that i know of thaf will do anything like thars is Metro PCS!
