using your iDevice as an external storage device
Discussion in 'iPad Hacking' started by VeGt0m, Jul 22, 2011.
  1. VeGt0m
    VeGt0m
    Jul 22, 2011
    43
    Hi. I have an iPad 3G/wifi jailbreaked 4.3.3 using jailbreakme. I have open SSH and winSCP. I have used this before to delete some bookmarks that would not go away from my springboard. Now, in regards to SSHing, would I be able to SSH into my iPod touch and drag my iPad iTunes backup into it to have a spare copy as I would using an external storage device? If so, where would I drag it?
    Thanks a lot! I'm new here too btw :). So hi everyone!
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    You could. In theory. But I'm not sure that's entirely practical, but you can do it if you want, for sure...
    When you log into your device with SSH you will land in the "root" home directory. That is fine if you want to create a folder in there for your backup stuff. Watch your capacity though! I'm assuming you have a small iTunes library if you want to do this?
    Storing backups which may regularly change on your iPad is not really a great use of flash storage. A cheap external HD is best for a backup. Or even a USB stick since your library must be pretty small to be able to be backed up on the iPad anyway.
    My personal opinion would be don't. But that's just me. And I have a 500+GB iTunes library! :)
    #2 f4780y, Jul 22, 2011
  3. Poser
    Poser
    Jul 2, 2011
    816
    27
    maybe not what you need, but phone drive is really cool.
  4. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    I have 2 gb of music and 5 gb of apps. Pretty small library. iPad has 3 gb free and it's a 16 gb!
  5. VeGt0m
    VeGt0m
    Jul 22, 2011
    43
    Hey, sorry for the late reply, but i just wanted to say thanks for the help guys! :)
how to use ipad2 as storage device
idevice.mnt external storage
use ipad 3g as storage device
