Use Airport Epress to send ipad web audio to amplifier?
Discussion in 'iPad 1 Forum' started by gglaze, Nov 10, 2011.
  1. gglaze
    gglaze
    Feb 26, 2011
    32
    Hi,
    I have an ipad 1 running ios 5 and an airport express.
    I really want to be able to send the audio from a radio
    website(App or website through Safari)to my audio
    amplifier. I can hook the APE up for itunes music but
    hope that I can use roughly the same setup for audio
    from a streaming radio station and send it to my amplifier.
    I thought Airfoil from Amobea would do this but am not clear that
    it would work for website streaming audio.
    I would appreciate any advice on how to do this.
    Thanks,
    Gary
  2. DefBref
    DefBref
    Apr 14, 2011
    978
    53
    You should just be able to do this via airplay, no need for any other third party software.
    As long as your ipad and airport express are on the same network you should see the airplay icon (a square with a triangle going in to it from the bottom) along with the playback controls, whenever you playback media, select that and you can redirect your audio to the airport express.
    Note some apps/websites restrict the use of airplay, but I've only ever seen this done for video not audio.
  3. gglaze
    gglaze
    Feb 26, 2011
    32
    Hi, Thanks for the reply. Looks like I need a cable so
    will get that and try it out later today.
    Appreciate it !
  4. gglaze
    gglaze
    Feb 26, 2011
    32
    Works great !
    Thanks.
  5. afc
    afc
    Aug 28, 2011
    20
    Sorry to take over this thread, but is it possible to do the same from a PC with a website/app that is not iTunes?
    Meaning, I can send the sound to my speakers via airport Express from iTunes (PC), iPad and iPhone. However, if I'm in a website (e.g., a radio website) using Chrome or Safari (ie., not using iTunes), I do not have the option to use the same speakers I use when playing music from iTunes for example...is there a way?
    Cheers,
    AC
  6. DefBref
    DefBref
    Apr 14, 2011
    978
    53
    For PC you will need third party software, Rogue Amoeba | Airfoil | Select Your Operating System for example. Your ipad, and iphone will work as already explained in the thread.
airport express not sending sound to stereo
sending ipad audio to amplifier
