USB tethering for web use...
Discussion in 'iPad 4 Forum' started by kdog2013, Mar 12, 2013.
  1. kdog2013
    kdog2013
    Mar 2, 2013
    18
    I was just wondering if there was a way to connect an iPad to a smartphone for internet connection. If possible would it matter if it was an android based phone or would it have to be an iPhone?
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,224
    As long as your cell phone is capable of creating a hot spot (and your carrier plan allows for it) - you should be able to connect the iPad to your phone. The iPad doesn't care where it gets a WiFi signal. As long as one is being broadcast, you can connect the iPad to it.
  3. Beards
    Beards
    Jan 11, 2013
    178
    13
    Yes, exactly as Marilyn states: I have an Android Galaxy S3 and use this as the Wifi provider. Again as already mentioned, ensure your plan has 'tethering' as an option, without it you could be in breech of your current terms of contract and could find yourself without a service.
  4. kdog2013
    kdog2013
    Mar 2, 2013
    18
    Hmmm... well I guess I was hoping I could do just that - connect to a phone so I would't icur hotspot charges....but not in a sneaky way. Ok. My phone has it but its not on my plan, thats why I asked. Thanks.
ipad usb tethering
