Unable to restore due to error 9 - fixable hardware problem?
Discussion in 'iPad Air 2 Forum' started by sgudmundsson, Aug 26, 2015.
  1. sgudmundsson
    sgudmundsson
    Aug 26, 2015
    Hi, everybody
    I'm having serious problems with my ipad. Few weeks ago I started getting BSoD but it was only yesterday I got the change to connect with iTunes on a mac to try to restore it. I got it connected and tried restoring both in regular restore and in dfu mode, but I always get "error 9", hinting at a connection problem in the iPad (if I understand it correctly).
    I took it to a local Apple repair shop and they get the same message, error 9, so that probably rules out problems with my computer. So the repair shop gave me two options, they could open it up to take a look and see if the could spot a hardware problem, e.g. with the dock or something else, that they could fix and then restore the software. This would probably cost about 15-25% of a new iPad.
    The other option is to just exchange the old iPad for a new one at half the price of a new one. This means the cost is considerably lower if they could just fix it without having to exchange it, but I have no guarantee that they'd be able to fix the iPad if they open it. The big problem for me is that if I choose the cheaper option, to let them open it to take a look, I can't take the exchange option afterwards if the other one doesn't work.
    So I'm wondering, does anyone have an idea how common it is for this error just to be a fixable hardware problem? I've no idea if I should choose to let them open it up, on the chance it works, or if I should just go straight for the exchange option.
    Thanks,
    Snabbi
  2. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    27,756
    9,615
    Which iPad do you own? If you have an older iPad such as an iPad 2 or 3, you might want to take the exchange option. Were you able to back up the iPad before the failed restore? If so, that backup could be used to set up a new iPad.
  3. Brian 244
    Brian 244
    Oct 20, 2014
    411
    443
    If you haven't done so already, check the dock connector for dirt/damage and try a different cable.
  4. sgudmundsson
    sgudmundsson
    Aug 26, 2015
    Thanks for the reply! I have an iPad Air 2, so it's new, only a little over one year old, but unfortunately only with a one-year warranty. Regarding the backup, I haven't done that but there's really nothing on the iPad that needed backing-up anyway so it'd be fine if I could just factory reset it, the error is just getting in the way.
    Thanks for that advise, I'll definitely check that. They tried resetting with another cable at the store though, you think it could still just be some dirt in the connector or damage? The iPad connected fine in the beginning, the computer apparently downloaded the necessary software and tried restoring the iPad. There even appeared a line on the iPad screen showing the process but after a while I got a really short-lived blue screen on the iPad, followed by black screen, and the "error 9" message in iTunes.
  5. Brian 244
    Brian 244
    Oct 20, 2014
    411
    443
    If it's an air 2 then it's still under warranty as it was only released in October of last year.
  6. sgudmundsson
    sgudmundsson
    Aug 26, 2015
    Aah, yeah, sorry about that. It's actually the first generation of iPad Air, not Air 2.
    • Informative Informative x 1
    • List
  7. Brian 244
    Brian 244
    Oct 20, 2014
    411
    443
    From what you've described I would go for the flat out exchange. There really isn't much that is fixable unless the shop is really good at board level repair ( many aren't) and the cost for board level repair might wind up equalling or surpassing the exchange cost. Like I mentioned earlier it could be the dock connector, but not likely based on what you described.
    • Like Like x 2
    • List
5s restore failed error 9 blue screen
error 9 apple ipad not fixable
error 9 hardware problem
error 9 iphone 5s blue screen
error 9 is fixable
ipad fixing error 9 hardware
is a hardware issue fixable on a i pad
itunes error 9 hardware
itunes error 9 hardware issue
itunes error due to hardware problem
