Tethered ipad wont charge or turn on! help please!
Discussion in 'iPad Hacking' started by Schmitty2364, Jan 17, 2011.
  1. Schmitty2364
    Schmitty2364
    Sep 17, 2010
    22
    okay so i have jailbroken my ipad with redsnow a like a month or 2 ago
    okay long story short...
    my ipad battery died so i went to charge it and retether it, only once its
    tethered and i plug it in and the pineaplle logo goes away it shows my display for a second and then it turns off because the battery dies or soemthing, it used to be that when this happened alls i had to do was hit slide to unlock before it powered down but now i cannot under any circumstances slide to unlock it before it turns off again! and now my sisters ipad is doing this too, any help or suggestions on how to fix this problem would be of great help
    thank you all for listening
  2. interhuso
    interhuso
    Sep 28, 2010
    Did you try to reboot with redsnow?
    with "Just boot tethered right now" option.
  3. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    Breathe. Just remember you can't brick an iPad. If worse comes to worse, just restore ~ and because you are JB, I am sure there is a special way to do that.
    Hang in there!
  4. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Have you have it plugged into a real ipad mains charger? Dont try and get it going with USB! Leave it plugged in for a while to get some charge (it will charge when off)
  5. mathen
    mathen
    Jan 7, 2011
    85
    10w charger coming along with ipad can charge them really fast, I have tried 5w iphone chargers,they do charge ipad but takes longer time...
  6. Taylor263621
    Taylor263621
    Dec 28, 2010
    96
    did you ever get it to work ????? Cause I never lost battery power...and wonder what happen in your case...
    thanks
  7. epin
    epin
    Jan 19, 2011
    I have exactly the same problem as Schmitty2364. It started on the 18th. When I rejailbroke the IPAD the Pineapple appears, then the login screen then it disappears and the power symbol appears and the IPAD dies. The problem is not the power as I have been charging it for hours and the power bar never increases. This is a Redsnow proble. Help Schmitty2364
  8. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Then it sounds like a hardware issue. If you have it plugged in and it never charges then it is definately hardware. Redsn0w has nothing to do with it. The iPad can charge when the OS is turned off. Nothing within the jailbreak can affect the ability of the battery to charge when the device is turned off. However, if the battery is flat then you should charge from the mains using the official 10W charger until you get sufficient power into the device. USB wont cut it.
  9. Shortman
    Shortman
    Dec 2, 2010
    I had this issue once; after charging for several hours the battery indicater never moved. As a longshot I went ahead and connected to the computer via usb and ran redsnow which worked. When the iPad finally loaded the battery indicator then displayed a half charged battery. I then hooked it back to the ac and completed the charge.
  10. jseyedanas
    jseyedanas
    Dec 22, 2011
    please some one help
    when i switch power button on my ipad 1, its sowing charging symbol blinking and in some time its going black screen...even i conected to my charger there is no responce to it ...when ever i try to on it its showing only charging symbol..
    and i tried even removing the charging dock from the board then i try to on it then also showing the charging icon blinking in red but its not switching on please some one help me.............kind request
    #10 jseyedanas, Dec 22, 2011
how to fix an ipad 2 that died and wont charge
how to turn on tethered ipad
i just loaded ios7 on my ipad and the battery went down to 0 and it wont charge at all. help
my ipad battery died and now it wont charge
my ipad died and now it will not charge or turn on
my ipad died and wont turn back on
my ipad wont charge or turn on
problem with ipad air battery died and wont come back on
tethered ipad died and
what to do when ipad 1 only gives a blinking battery but wont charge
