Streeming audio stops after 1 minute
DH58
Burlington, Ontario Canada
Recently two apps started to pause while playing approx. 1minute after start. The audio and video will continue to pause, again every 60 seconds.
The two apps had worked for months no issues.
The two apps are MLB.com and Netflix.
Has anyone encountered the same, what is the cause and is there a fix?
Tim SPRACKLEN
