Still have syncing problem
Discussion in 'iPad Help' started by DEKA2010, Oct 15, 2011.
  1. DEKA2010
    DEKA2010
    Oct 8, 2011
    12
    I downloaded few apps with my ITunes but when I synced to my IPad some worked some did not work, and the way my actual screen and the way it looks in iTunes is totally difference though I synced it several times it still looked different, can anyone here know what to do ?
  2. richsadams
    richsadams
    iPad Super Guru
    Mar 23, 2011
    3,500
    99
    Simply restarting the iPad can fix most issues. Hold down the power switch (outside edge) by itself until the red slider appears. Turn it off by sliding the switch and then once again hold down the power switch until the Apple logo appears.
    Resetting the iPad should be reserved for a non-responsive unit as it addresses other activity but if restarting doesn't do it, resetting it might. Hold down the power switch and home button until the slider appears on the screen and shut it down. Hold down the power switch again until the Apple logo appears. Fully booting up from a reset will take a little longer than a restart.
    More here:
    iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    Let us know if that helps. Others may have some more suggestions as well.
