SSH problems
Discussion in 'iPad Hacking' started by zachdrago, Jun 24, 2010.
  1. zachdrago
    zachdrago
    Jun 24, 2010
    is anyone else having SSh problems? my ipad rarely connects via CyberDuck, and when it does it usually disconnects me 10 seconds later..
  2. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    reinstall it and remember to change the default password so that your ipad doesnt get hacked.
  3. gillon
    gillon
    Jun 29, 2010
    I have had to reinstall openssh on my iPad everytime I want to connect.
  4. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    If you have SBSettings installed it also gives you the option to turn SSH on and off.
  5. peeempz619
    peeempz619
    Jun 30, 2010
    6
    Try Fugu if you're using a Mac. I've never had an issue connecting to my iPad.
  6. gouletjo
    gouletjo
    May 31, 2010
    65
    Sorry guys how can I changed my password in ssh ? Other than fugu for Mac, do you have a windows alternative ?
  7. Mv-ixius
    Mv-ixius
    May 29, 2010
    16
  8. gouletjo
    gouletjo
    May 31, 2010
    65
    Does it work with itunes 9.1.1 ? Because it's written "for Itunes 9.2"
  9. Mv-ixius
    Mv-ixius
    May 29, 2010
    16
if iphone safari hacked 2013 ssl ssh html
ipad ssh problem
ipad, fugu ssh
password for ipad ssh does not work
