Spotlight problem with iPad 2 running iOS 8
Discussion in 'iPad 2 Forum' started by Ser Aphim, Sep 23, 2014.
  1. Ser Aphim
    Ser Aphim
    iPad Addict
    Nov 7, 2013
    1,023
    171
    I want to know who else has this and if there are any fixes for it. I already tried a hard reset.
    Remember those new spotight features? I don't have them. There are 2 new things I found in the spotlight section, the spotlight suggestions and bing results, whenever I try to tap on them they get a check mark on their side, when I search for something it seems as they don't work at all and when I come back I find them uncehcked. This has been frustrating especially since this is one of the most awaited features for iOS 8, at least in my opinion.
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,734
    6,680
    If you have not already done so, you could try Settings > General > Reset > Reset All Settings. You'll have to do a lot of re-tweaking of settings afterwards, but it might unstick whatever is stuck.
  3. Ser Aphim
    Ser Aphim
    iPad Addict
    Nov 7, 2013
    1,023
    171
    I'll see if that does anything. I'll tell ya'll if things go dandy.
  4. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,734
    6,680
    Fingers crossed.
  5. janner43
    janner43
    Jun 25, 2012
    167
    26
    Sorry but I don't like the surrounding issues with a lot of these new "improvements". So I have them turned OFF - one of the reasons I prefer iOS to Android. In iOS I have control. :)
  6. Ser Aphim
    Ser Aphim
    iPad Addict
    Nov 7, 2013
    1,023
    171
    Still no luck. Maybe this is a bug.
  7. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,734
    6,680
    Possibly. I can't duplicate the problem, but since were are using different iPad models that means little.
  8. Ser Aphim
    Ser Aphim
    iPad Addict
    Nov 7, 2013
    1,023
    171
    Heard about iOS 8.0.1 update, sounds like a rumor, and rumors doesn't say anything about any spotlight issues. Looks like a full restore is my next stop.
  9. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    18,608
    10,989
    The update was available for a short time and was withdrawn, because there were problems with iPhones. The next update is in progress, and will be available as soon as possible.
    There were no fixes for the spotlight feature in iOS 8.0.1, though.
    #9 J. A., Sep 25, 2014
  10. Ser Aphim
    Ser Aphim
    iPad Addict
    Nov 7, 2013
    1,023
    171
    Installed iOS 8.0.2, did not fix anything. Aight I'm restoring it now.
ios 8 spotlight problems
spotlight ios 8 ipad
