Speaker problem!
Discussion in 'iPad Help' started by Hedgehog, Jun 5, 2011.
  1. Hedgehog
    Hedgehog
    Jun 5, 2011
    Since using headphones I have lost sound on some apps? Any help appreciated!
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
  3. Hedgehog
    Hedgehog
    Jun 5, 2011
    Greatly appreciated - problem solved! Many thanks....
apple ipad speaker problems
blown speaker on ipad
ipad 2 speaker problem
ipad 2 speaker problems
ipad 3 speaker problem
ipad 3 speaker problems
ipad speakers blown
speaker on ipad not working
