Sound
Walsallmum79
I don't seem to have any sound on my games but it's turned on in settings. Can anyone help?
idave23
Illinois
Just happened to me. I turned it off by pressing the home and power buttons. Let it sit for a bit and powered it back up and the sound was back.
Czevski
Weston WI
Double-check your sound settings by double pressing the home button and then swiping the lower bar to the right. You will see both the sound level and if mute is on. I somehow accidentally had mute on for one app I was using.
