Sound
Discussion in 'iPad Help' started by Marlorr, Sep 26, 2013.
  1. Marlorr
    Marlorr
    Sep 26, 2013
    Own loaded iOS 7. Now have no sound on iPad.
  2. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,837
    1,306
    Hi and welcome to the Forum!
    You haven't inadvertently switched the side switch to mute? It's found just above the sound toggles on the side of your iPad.
    Try a reset of your iPad and see if this fixes your issue.
    Hold the power off button and the home button simultaneously, keep holding them in and you may see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start. Let us know how you go.
    In the meantime, I've moved your thread to our Help Section where you will receive a better response.
    https://itunes.apple.com/us/app/discussion-forum-for-ipad/id412896524?mt=8
    Tutorial for our App
    http://www.ipadforums.net/new-membe...sistance/107524-ipad-forums-app-tutorial.html
    Tutorial on creating posts on the Forum
    URL="http://support.apple.com/manuals/"]Apple - Support - Manuals[/URL][/QUOTE]
    http://www.ipadforums.net/new-membe...1590-tips-tricks-those-us-who-don-t-know.html
