Sound of keyboard and slide to lock and such gone?
Discussion in 'iPad OS' started by STi, Nov 23, 2010.
  1. STi
    STi
    Sep 2, 2010
    98
    After I upgraded to 4.2..I have no sound on keyboard buttons and the little sound when you slid to unlock and sleep button..no noises...have they been removed or am I missing a setting?
  2. chandar
    chandar
    Jun 29, 2010
    27
    Did you check in settings?
    Settings --> General --> Sounds --> see if the lock sounds and keyboard click is set to off
  3. STi
    STi
    Sep 2, 2010
    98
    I figured it out..I had my screen locked to sideways before update and it muted it...The new mute button had me fumbling around lol!
  4. Durgadas311
    Durgadas311
    Nov 24, 2010
    The rotation lock was removed and now it is mute? What if I want to disable rotation?!
  5. Irish Rose
    Irish Rose
    Nov 23, 2010
    234
    Click the home button twice, to bring up the multitasking bar. Then slide all the way to the right, till you come to your iPod settings. The orientation lock is on the left. Its one more step and less convenient, but it works.
  6. Durgadas311
    Durgadas311
    Nov 24, 2010
    Thanks for the reply, but I can find no orientation lock control in the iPad Settings. Is there some other thing that I should be looking for, or are you referring to that same Settings as one uses to select wallpaper and control networking?
  7. Durgadas311
    Durgadas311
    Nov 24, 2010
    Found it! When you said "right" I was looking at the right end of the multitasking slider, not the left end which one gets to by sliding right.
    Thanks!
  8. Sanjeev Gupta
    Sanjeev Gupta
    Dec 1, 2010
    i am also facing same problem since I upgraded to 4.2..I have no sound on keyboard buttons and the little sound when you slid to unlock and sleep button..no noises...have they been removed or am I missing a setting. some =body plaese help
  9. Superbike81
    Superbike81
    iPad Addict
    Feb 1, 2010
    1,128
    Did you read above?
    Remember the switch above the volume control? Flip it up, then you will have sound again.
  10. Slimpeek
    Slimpeek
    Sep 18, 2011
    Sending audio through AirTunes?
    Hi all, so this was my issue. I doubled clicked the home button and noticed that earlier, while playing music on my iPad, I was sending the audio using AirTunes, and that's why I wasn't able to hear my keyboard clicks. So just turned the sound back to play through the iPad. That was it. Simple. Though I killed tons of neurons figuring it out, haha!
    Cheers!
how to make keyboard soundwork on ipad
ipad keyboard clicks no sound
ipad keyboard sounds not working
ipad no keyboard clicks
keyboard clicks and lock sound not working ipad mini
no keyboard clicks on ipad
no keyboard sound ipad
no sound on ipad keyboard
why can i hear some lock soud and keyboard clicks on ipad air
why no keyboard clicks on ipad
